2002 Dodge Durango rear
Old Nov 12, 2012 | 05:24 PM
Adisturbedal's Avatar
Adisturbedal
Default 2002 Dodge Durango rear
Hi I have a ? I have a 2002 Dodge Durango with a bad rear end. My ? Is what is the easiest way to change the rear out. I have been doing research most people are saying pull axles and remove the backing plates so u don't have to mess with the brake lines. Others are saying drop the rear shackles on the leaf springs. What is your options on the best way.
Old Nov 12, 2012 | 08:14 PM
shrpshtr325's Avatar
shrpshtr325
THE ULTI-MOD
https://dodgeforum.com/forum/dodge-d...s-section.html
honestly your best bet is most likely going to be having a shop do it, gear work is very tricky and is not something for a beginner to do (idk what your skill level is so im putting this out there)
im also moving this the first generation section.
Old Nov 12, 2012 | 08:42 PM
Adisturbedal
Well I'm looking to swap out the whole rear no money for shop work. I've put in engines, transmissions, did head gaskets and things like that .
