2002 Dodge Durango blower motor
Old Nov 13, 2012 | 12:14 AM
Shannon Martin Myers's Avatar
Default 2002 Dodge Durango blower motor
My blower motorwent out and so I replaced it wih a new one, its still not working. I have checked fuses and made sure blower works by connecting to battery and it works fine. Anybody have any other suggestion to which I hould check?
Old Nov 13, 2012 | 06:01 AM
shrpshtr325's Avatar
shrpshtr325
THE ULTI-MOD
https://dodgeforum.com/forum/dodge-d...s-section.html
check the approprate relay for the blower.
also im moving this thread to the first generation section where it belongs
Old Nov 13, 2012 | 10:15 PM
I have checked the relay under the hood
Old Nov 14, 2012 | 01:12 AM
cummingetit's Avatar
cummingetit
Will it work on full blast? If it does then the blower motor relay is bad. Its where the wires plug into the bottom. 5 prong plug iirc. If it doesn't a bad selector switch maybe? Have you checked for voltage at the motor connectors?
Posted from Dodgeforum.com App for Android
Old Nov 14, 2012 | 04:38 PM
Old_School's Avatar
Old_School
sounds like the blower motor resister.
Old Nov 14, 2012 | 09:29 PM
shrpshtr325
THE ULTI-MOD
if it works on full blast only the issue is the resistor, not the relay
Old Nov 19, 2012 | 09:44 PM
994x4rango's Avatar
994x4rango
New Member
Not to sound like an idiot, but where is the blower motor located? I've looked under the dash and don't see it.
Old Nov 20, 2012 | 01:08 AM
cummingetit
Opps Sry i meant resistor, the blower Motor is under the dash on the passenger side. its circular and there is a plug with 5 wires (at least on mine) that go to the resistor which screws into the bottom.
Old Nov 20, 2012 | 07:07 PM
994x4rango's Avatar
994x4rango
New Member
Thats what I'm sayign cummingetit. I don't see it. I hope it isn't one where the dash has to come out for that too. Nothing wrong with mine just saying.
Old Nov 21, 2012 | 01:25 AM
cummingetit
My apologies, i just looked under my 99s dash and i can't see mine either, i was referring to my 01 originally. It appears as though it is behind the glove box but its dark out. I'll try to look better tomorrow.
