2001 Dodge Durango SLT won't restart when warm,
Hey guys! This issue I'm having is that the truck won't after I've driven for any significant amount time. I have to wait till it cools down for it start again. It turns over but won't start! Any help or suggestions are much appreciated, thanks!
i would check the crank and cam position sensors to start with, as long as it will run 'indefinitely' and not stall out/shut itself down i wouldnt expect it to be a PCM issue without first ruling out the smaller, much much cheaper items first
I am having the exact same problem as you. It drives like a champ then when I try to restart it it just cranks and cranks. If i wait 45 minutes or so it fires right up. I got it to stop doing this by replacing the distributor cap/rotor. Now 1 month later.... same thing again....looked inside the distributor cap and its all carboned up again. I cleaned the contacts and vroom.... Now, once again, same problem again. If I hit the distributor with a soft hammer it also start right up! I replaced these parts already so I am thinking maybe cam sensor or ignition coil at this point, what do you think?
1998 Dodge Durango 5.2
Alright! Replaced the PCM with a new unit from Autocomputer Exchange and so far the problems solved! Thanks for everyone's input and advice! Mcboden, I would try the PCM! Ordered Monday, got it Tuesday afternoon. Best of luck and thanks again!
