p1732 and p0765
Old Dec 10, 2012 | 03:27 PM
David Schoenling's Avatar
David Schoenling
Post p1732 and p0765
I have a 2000 Dodge Durango 4.7l 4 wd. Today as I was driving I noticed it was not shifting into O/D and was slow off the line, like it wasn't in 1st gear on take off... This is an automatic transmission by the way... I ran a code check and got the following codes... P1732 (Under pressure switch check) and P0765 (shift solenoid D malfunction).
First question is, where is the shift solenoid located, and second question is this a job for a DIY mechanic?
Any direction would be helpful...
Thanks!
Old Dec 10, 2012 | 05:21 PM
shrpshtr325's Avatar
shrpshtr325
THE ULTI-MOD
https://dodgeforum.com/forum/dodge-d...s-section.html
ill move this for you
