Do you have a timing light and maybe a vacume gauge? If so you might be able to find this miss is limited to one cylinder. How did the spark plugs look.
You may have a bad temp sens telling the computer to run very rich. Or maybe if the miss is on one cyl. a bad injector.
Maybe one of your plug wires or boots is allowing an arc? I had this problem with my '98. The easiest way to check it is to open the hood at night and disconnect the underhood light. Look for any indication of arcing (spark) along the wires and near the plugs.
