2002 Durango Heater Fan not working HELP!
Old Dec 22, 2012 | 07:28 PM
Paul Dilley's Avatar
Paul Dilley
Default 2002 Durango Heater Fan not working HELP!
Hello All, I hope you can help me! I have replaced the Motor, Resister Card and swapped out the heater control panel with one that I know works... still NO JOY!
The fuse is good... and from what I can tell with swapping around relays in the fuse box under the hood... it's not a relay...
HELP! 3 months without a freekin heater is starting to really get old!
Old Dec 23, 2012 | 03:37 AM
go-part's Avatar
go-part
Former Vendor
Check your electrical system, it sounds like you aren't getting any power to the blower motor.
Old Dec 23, 2012 | 09:45 AM
shrpshtr325's Avatar
shrpshtr325
THE ULTI-MOD
you need to get a voltmeter out and figure out where you loose the voltage to the system, do you have voltave to the motor? no, what about the resistor? or the control panel? or the relays?, there has to be an open in the system somewhere you just have to find out where
