ABS module
Hey folks,
I haven't been here for awhile. This past summer I bought a '99 D and had to do some "modifications" to the brake system. In fact, I had to bypass the ABS system to get the D on the road. I am now in a position where I can get the ABS working. The pump works, but the module itself was left empty for about a year and was clogged and corroded (hence the bypass). It's a 3 wheel ABS system. Does anyone know of a supplier that I can order the unit from? I don't need the actual controller that the connector plugs into. I need the unit the brake lines attach too.
I checked Autozone, Advance and Napa...no go. I also checked rockauto with no results. Any direction would be appreciated.
Thanks folks.
Thanks folks.
