New battery/now Stalls at Idle(computer?)
Old Jan 7, 2013 | 01:15 PM
buffalocalzone's Avatar
buffalocalzone
Default New battery/now Stalls at Idle(computer?)
Hey Guys- quick question, i just put a new battery in my 2003 Durango 4.7 and only had time to drive it a mile or so during my Lunch break- however after putting in New battery it wanted to Stall out while in Idle- do I have to reset the computer or will it do it on its own after driving it for a few more miles? i've read different scenarios on this issue, just wanted to get some 'professional' solutions and if anyone has had this issue after installing New battery- thanks for any input
Old Jan 7, 2013 | 02:04 PM
Duralude09's Avatar
Duralude09
the computer is relearning how to run. did have any issues before the new battery?
Old Jan 7, 2013 | 02:06 PM
buffalocalzone
none at all- so i just run it for some more miles and it should reset itself?
Old Jan 7, 2013 | 03:06 PM
c0a8l0v6i8n9's Avatar
c0a8l0v6i8n9
To reset disconnect the negative terminal, turn the key to start for 30 seconds, then reconnect the negative. That will reset the computer.
Old Jan 7, 2013 | 03:12 PM
buffalocalzone
Thank you-
Old Jan 7, 2013 | 08:26 PM
shrpshtr325's Avatar
shrpshtr325
THE ULTI-MOD
when you removed the battery you reset the PCM to factory defaults, give it a week or so and see if it goes away, if so dont worry about it
Old Jan 8, 2013 | 07:07 AM
buffalocalzone
Excellent- thanks Guys (everyone) i've driven it since yesterday and seems to be Idleing fine now, appreciate all your help
