I have a 2000 Durano 4.7L. The check engine light came on. Engine is running fine. My neighbor has an OBD, so we checked for a code. The scanner showed no pending codes, and could find no codes althogether. He reset the light, but it came back on as soon as I started the engine. We tried several times, but the light will not reset.
get the d to read them to you. turn key from off to run position three times and leave on the 3rd time where the odometer display is it will say codes and when its done it will say Pdone
I had that same thing. Check light, no code. I started checking all the grounds that were easy to get to, and cleaning them off. I also reset the computer 6 or 7 times. That ended up working for me.
Paul...make sure you have the correct gas cap installed (and that it is tight)...the problem could also be the Clockspring (reference Haynes manual for location and removal)...good luck...
