Oil Pressure gauge problem mabe more.
Old Jan 11, 2013 | 06:40 PM
Vrnmrgn's Avatar
Vrnmrgn
Default Oil Pressure gauge problem mabe more.
I have a 2001 dodge Durango with 128+ miles. The oil pressure gauge kept going from low to 1 quarter and the check gauges light would come on and go off. I took it to Autozone to check the the codes and the said it the only code was p500 speed sensor which I already knew about. It was about 2 quarts low on oil so I topped it off. On the way home the gauge went to low & did not come up. I parked the truck. Later my wife went to pick up the kids with the truck when she got back the truck was making a knocking noise. I was taking it to the shop in the morning. Am I out of luck or is there a chance it is not that bad. What could be wrong.
Old Jan 11, 2013 | 08:33 PM
dolittle's Avatar
dolittle
At first I would have recommended to install a mechanical gauge. But if it is knocking now it will probably be a rebuild.
Old Jan 12, 2013 | 09:11 AM
Vrnmrgn's Avatar
Vrnmrgn
How much does a typical engine rebuild cost?
Old Jan 12, 2013 | 11:22 PM
moe7404's Avatar
moe7404
if you put a mechanical gauge in ONLY use a break line tubing. there i a new tubing, called niopp. i have not used it but the specs are very good. DO NOT use anything eles.
