Cruise control not working
Old Jan 20, 2013 | 09:34 PM
adukart's Avatar
adukart
Default Cruise control not working
Hey guys been searching for an answer but cannot find it. Its been an issue for a few months now but my cruise isn't working. The light on the dash comes on but nothing will happen. Where should I start with this? Its getting on my nerves now. Thanks
Old Jan 20, 2013 | 10:54 PM
Old_School's Avatar
Old_School
It could be anything from a vacuum leak to a bad servo or a bad electrical component/connection.
I would start by getting a copy of the 1998 FSM (if you dont already have it).. then, i would start easy and check that vacuum lines and electrical connections...
98 FSM ~~> http://www.mediafire.com/?xu9h0gt9bdcn6#95xauggyi3uc3
Old Jan 20, 2013 | 11:38 PM
adukart's Avatar
adukart
Thanks for the link, I tried the link in the DIY sticky and couldn't get it to work but this one does.
Old Jan 21, 2013 | 03:10 PM
shrpshtr325's Avatar
shrpshtr325
THE ULTI-MOD
check for vacuum leak and your brake switch, if the truck thinks you are on the brakes it turns off the cruise
Old Jan 21, 2013 | 04:23 PM
adukart's Avatar
adukart
It happened when I was workin on my a/c so i'll start under the hood.
Old Jan 21, 2013 | 11:28 PM
srch4me's Avatar
srch4me
Check vacuum lines. Especially the passenger side on the firewall
Posted from Dodgeforum.com App for Android
Old Jan 29, 2013 | 05:12 PM
adukart's Avatar
adukart
You called it, the vacuum line to the cruise motor was kinked where it attaches in between it and the firewall. It was also almost pulled off the vacuum reservoir in the passenger fender. So I un-kinked it and pushed it back on the reservoir. It also solved something else. Under heavier throttle, going up hill still in 4th, it would drop from dash vents to floor. Now it holds.
Old Jan 29, 2013 | 10:04 PM
melodytoinvent's Avatar
melodytoinvent
I don't know why but this is what went through my head when I got to the end of what you said...
Old Jan 29, 2013 | 11:33 PM
adukart's Avatar
adukart
Nice, I kinda felt like that too
