100,000 mile maintance
Old Jan 22, 2013 | 09:40 PM
tooltime's Avatar
tooltime
Default 100,000 mile maintance
The Durango will have 100,000 miles in a few months and want to know what kind of maintance i need to do? I do not have a manual and i have replaced the spark plugs,throttle postion sensor and the crank sensor. Should i change the trans fluid and have the filter cleaned? It is a 2001 4 wheel with a 4.7. The belt looks good. What about the timing chains and the fuel filter? thanks
Old Jan 23, 2013 | 05:49 AM
shrpshtr325's Avatar
shrpshtr325
THE ULTI-MOD
the 100k maintance items are the trans fluid/filter (replace only do not flush) and the serpentine belt iirc, as stated check your owners manual, if you belt still looks good grab a new one and throw the old one in the back, if the one lets go on the road you have so met hing to stick on it on the side of the road
Old Jan 23, 2013 | 06:39 AM
tooltime's Avatar
tooltime
I don't have a owners manual
Old Jan 23, 2013 | 10:12 AM
JeeperDon's Avatar
JeeperDon
I do have an '01 FSM, and the only item shown specifically at 100k is trans fluid/filter. Everything else in the 100k'ish area is normal 30k interval stuff and oil changes.
