98' Durango 5.2 speedomiter problem
Old Feb 13, 2013 | 02:33 PM
Basolisk's Avatar
Basolisk
Default 98' Durango 5.2 speedomiter problem
I have a speedometer problem that has me baffled. Most of the time it will not work, but when it rains or is damp out it will work but not properly. When it dose work it will only register half the speed I am going till I get above 70kph(40mph) and if I hit a bump it will bounce back to 0 the pick back up. I have a Obd2 computer and the engine code that is on is the speed sensor. I have replaced it but with no luck. Any ideas out there in Dodge land????
Old Feb 13, 2013 | 02:51 PM
Russ50's Avatar
Russ50
Sounds like your prob is in the dash part of the cluster,,
Old Feb 13, 2013 | 06:45 PM
Old_School's Avatar
Old_School
witch speed sensor did you replace?? your truck has 2 one on the side of the transmission and one on the rear axle... both are prone to fail, it is recommended to replace them as a pair..
Old Feb 13, 2013 | 07:23 PM
Basolisk's Avatar
Basolisk
Never know there was one in there rear end. Where in the rear end is it located?
PS
Ahh Never mind, found another post showing where it is.. Thx going to try it tomorrow.
Old Feb 13, 2013 | 08:49 PM
Russ50's Avatar
Russ50
I have tryed replaceing both with new ones an still can't get mine to work an the same on my son 99 D,,,
Old Feb 13, 2013 | 08:59 PM
Old_School's Avatar
Old_School
PS
Being that it works sometimes when wet i would say there is either a bad connection or a bad sensor or both.. The speed sensor on the axle is where the signal for the speedometer comes from... good luck and keep us posted!
Old Feb 13, 2013 | 10:00 PM
shrpshtr325's Avatar
shrpshtr325
THE ULTI-MOD
defintely dont spend money on a clust right now, since the problem is weather related it is clearly related to water getting into one of the control circuits
Old Feb 14, 2013 | 11:48 AM
Basolisk's Avatar
Basolisk
Got the sensor today but am unable to install it right now. Going to have to hold off for a week.
Tell me this tho.. Why is it at Dodge this sensor is $75 and at NAPA and CARQUEST it is about $110, Then a starter (another job I need to do) at Dodge is $220 when at NAPA and CARQUEST there $150?
Old Feb 14, 2013 | 04:14 PM
Russ50's Avatar
Russ50
Parts place like Auto Zone they cost lil under 35 bucks for either one of them,, But thats just for the sensor only
Old Feb 14, 2013 | 04:54 PM
Old_School's Avatar
Old_School
Because it is NAPA and they SUCK!.. c'mon they have to make money to support Michel Waltrip's pension...
If you don't mind having things shipped to you i have always found excellent prices with www.rockauto.com
