2000 Durango tranny issue
Old Feb 14, 2013 | 12:02 PM
t_johnson44's Avatar
t_johnson44
Question 2000 Durango tranny issue
I have a 2000 Durango with a 5.9 motor. I went to put it in reverse the other day and it started grinding to beat hell and went nowhere. I put it in drive and it took right off. When I let off the gas and letting it coast I get the same grinding noise I get when I put it in reverse. Does anyone know what is going on?
Old Feb 14, 2013 | 12:32 PM
Basolisk's Avatar
Basolisk
Are there any codes coming up on your computer? If so what are they. Also I see you Durango is a 2000. What millage do you have on it? Might be time for a rebuild. Did mine around 300,000km. Is the trany fluid burnt or have any metallic flakes in it? A trans has a ton on moving parts that can go wrong. My first guess tho might be the governor.
Old Feb 14, 2013 | 03:30 PM
t_johnson44
It has 210,000 miles but I've only had it for 3 years so I don't know if the tranny has been replaced/rebuilt before. I have not removed the pan yet but the fluid on the dipstick doesn't smell or look burnt to my knowledge. I will check codes and inspect fluid closer tonight. I have also heard nightmare stories about frequent rebuild failures. Would I be better off buying a remanufactured transmission if it does need to be replaced?
Old Feb 14, 2013 | 11:10 PM
Basolisk's Avatar
Basolisk
Remanufactured is just another way of saying rebuilt but it is someone elses trany. If you get it rebuilt get it done at a place you know and trust. It's not a small job but not the biggest. I had mine done at Dodge and it run me about $1000 with tax and they garanted it for a year.
