Trying not to beat a dead horse...
I have been just generally typing in the issue I am having with my durango, and there seems to be SEVERAL possible answers to this common issue. It all started a few months ago after I had to drive the D for work for a week. I would apply the brakes and the oil pressure would dump, and come right back(1-5 seconds). I replaced the PCV valve, the plastic elbow on the drivers side valve cover(the whole part). I went through and replaced most of the vacuum lines because a few had oil in them. The check gauge light was less frequent, then...it became every time I put my foot on the brakes. So I replaced the oil pressure sending unit, and the MAP sensor, and now it bounces from 0-70psi about every 30 seconds. I bought stuff to do an oil change, and will see if that helps.
Here is my question, is it just a good idea to go ahead and hook up a mechanical oil pressure gauge, or should I buy an oil pressure gauge kit...or both? I am not sure how much more money I want to throw at it, but I have to keep it on the road for at least a year. I have even debated on just buying a used motor and throw in it, and rebuild this one and sell it. Again, fearing I will continue to run into the same issue. Just looking for a few opinions.
<---don't want to do that...
I am also gonna be replacing the spark plugs, if I see anything out of the ordinary I will take pics and post them. I may since I have the extra money, go ahead and replace wires, cap and rotor as well, can't hurt. Also, it seems that the 5.2(and probably 5.9) are vacuum based...could a bad brake booster cause some of this problem as well?
i would go ahead and install the mechanical gauge and see what it does... i remember Sharps having the same issues (i believe his was sending units kept failing?) anyways he installed a mechanical gauge and still kept the stock one... maybe he can give you more insight on it..
Well, I went and bought a mechanical oil pressure gauge, install took about an hour(my first install). I did the oil change, plugs had some carbon built up, so I replaced them. Oil pressure is staying steady about 70psi, and about 50psi after it gets warmed up... I took it out in the country, hammered on it a few times...and it stayed where it should. So far so good..I may drive it to work a couple days and see how it does...
