Idling Issue and while driving too...Pls Help
Old Feb 21, 2013 | 12:11 AM
XLYNX's Avatar
XLYNX
Question Idling Issue and while driving too...Pls Help
this has been happening for 5 months but progressivly getting worse and worse.. I start the truck and a huge hissing sound from front engine, ( replaced IAC 2 times now still not a fix for that ), also when i start driving i'll get to about 20-25 sometimes 30-35 then the engine doesnt die but hesitates rpms go down to 600 then i hear a POP POP POP until i let off the gas, but then if i hit the gas it starts popping again so i have to pull over shutdown restart and then its good , this issue happens when ever it wants to somedays nothing at all and others all day long , The Popping sound appears to be in front of me not below ( trans area ) or the rear. ANY IDEAS will be greatly appreciated, i have a baby due on the FEB 28th and this is not what i want to be thinking about right now
Old Feb 21, 2013 | 06:22 PM
shrpshtr325's Avatar
shrpshtr325
THE ULTI-MOD
the hissing sounds like a vacuum leak to me, find it and fix it and see what happens, they can cause all sorts of weird problems
Old Feb 23, 2013 | 03:39 PM
98beast's Avatar
98beast
Get the trucks codes checked. My durango is doing the same thing. It wants to turn off and it idles really low. Check the throttle position sensor it runs like 30 bucks and is easy to replace its right on top of the engine..
Let me know how it goes.
Old Feb 23, 2013 | 03:42 PM
98beast's Avatar
98beast
Also youtube is a very good place to get usefull info from.
Old Feb 24, 2013 | 11:03 AM
shrpshtr325
THE ULTI-MOD
you tube is a good place to get misinformation from too if you dont know what your doing, the 'helpfull' videos on there are hit or miss as to their accuracey
Old Feb 24, 2013 | 02:09 PM
XLYNX's Avatar
XLYNX
Default found the issue
governor pressure sensor wire was shorting due to a chaffed wire
