Over sized caliper bolt question
Old Mar 1, 2013 | 08:38 PM
sparkmarv's Avatar
sparkmarv
Default Over sized caliper bolt question
Bought my Durango used.. shortly after i changed the brake pads, but had to use a Dorman oversized caliper bolt, due to the bolt hole being striped.
Here soon im going to be getting new rotors, calipers, and pads, do i just reuse the oversized bolt? its self tapping, so cant help to think that using it twice could cause further damage.
Old Mar 2, 2013 | 12:06 AM
IndyDurango's Avatar
IndyDurango
Use it twice, three, four times is fine. Run it out very easy and hand thread it back in like a normal bolt. You do NOT want it to be cutting any new threads the next usage. If you are careful and get the bolt in straight, by hand, smooth and easy, you can use it over and over.
If you mess it up, new knuckle time or heli-coil (easier and cheaper) time.
HTH,
IndyDurango
Old Mar 2, 2013 | 09:27 AM
that_guy's Avatar
that_guy
HTH,
IndyDurango
Old Mar 2, 2013 | 07:16 PM
sparkmarv's Avatar
sparkmarv
Thats the answer I was expecting, sry for the silly question, but I couldnt find any info anywhere about this.. thx guys.
Old Mar 2, 2013 | 07:23 PM
that_guy's Avatar
that_guy
It's not a silly question if you genuinely didn't know.
