IF anyone can
Old Mar 11, 2013 | 11:32 PM
MrDurangoRT's Avatar
MrDurangoRT
Default IF anyone can
hey i know some1 out there has the unlimited carfax i cant afford it esp after paying over 1k for repairs on my durango i just bought 2 days ago.. but if some1 that has the unlimited carfax report if they could check my vin n let me know history so i know if anything was done to it or if it was just toss around junk
1B4HS28Z1YF295305
and second note its normal around 30'f here atm my oil pressure is always from start to 30 mins down the road around the high end more to the high then the normal side of the bar temp stays cool-normal but the oil pressure is worrying me frist thing i tried was getting mobil1 full synthedic and new mobil1 filter put on it same thing nothing changed so maybe pump need replace? idk. and also when dirving it seams to take a really long time to shift and get shifted it will wind in frist gear kinda to 3k rpm or so but then takes like idk how long like 2seconds + to even shift to second then same 3'rd to 4'th and in 4'th it seams really winded out doing near 2k rpm at 35mph the tranny is just rebuilt a week b4 i bought it i have somwhere a recipt the guy gave me showing date and cost ect dident think much of it it ran perfect frist day then alot happen and kinda worried the tranny is about to mess up
anyways any adivce or help at all would really help thanks
Old Mar 11, 2013 | 11:34 PM
MrDurangoRT
its just about to hit 157k miles engine looks really clean verry little old oil on bottem of pan thats it. i already got almost 5k into this and unless i trade it for somthing as a str8 trade im kinda screwed without a car untill i can save up next year or so.
Old Mar 11, 2013 | 11:44 PM
master tech's Avatar
master tech
Site Moderator & Tech
I don't have access to carfax, But maybe some of theis would help. All the recalls were already completed before 2003.
Page: 1
Vehicle Option - All
Standard Equipment
Code Description Code Description Code Description
ADAS Light Group AJKS Convenience Group APAS Monotone Paint
BAZS 136 Amp Alternator BGJS Pwr Disc/Drum Rr Anti-Lock Brakes BKAS 11x2 Rear Drum Brakes
CBWS Highline Door Trim Panel CGWS Next Generation Front Air Bags** CJTS Seat Track Cover
CKAS Carpets - Floor and Cargo Area CKTS Cargo Tie Down Loops CSRS Passenger Assist Handles
CURS Rear Compartment Storage Tray DGTS 4-Spd. Automatic 46RE Transmission DJDS 205MM Front Axle
GBBS Tinted Windshield Glass GCBS Front Door Tinted Glass GEGS Deep Tint Sunscreen Glass
GFAS Rear Window Defroster GMLS Liftgate Door w/Fixed Glass GXRS Keyless Entry
HAAS Air Conditioning HGAS Hood Insulation JAAS Instrument Panel
JAYS Instrument Cluster w/Tach JBFS Instrument Panel Black Bezel JCBS 120 MPH Primary Speedometer
JHAS Var Intermittent Windshield Wipers JHBS Rear Window Wiper/Washer JJAS Cigar Lighter
JJBS Dual Note Electric Horns JJMS Auxiliary 12-Volt Rear Power Outlet JPBS Power Locks
JPDS Power Windows, Driver One-Touch LACS Illuminated Entry LAFS Key in Ign/Seat Belt Warning Buzzer
LAJS Headlamps On Warning Chimes LALS Low Washer Fluid Warning Signal LAMS Door Ajar Warning Lamp
LANS Decklid/Liftgate Ajar Warning Lamp LDGS Liftgate Flood Lamps LMBS Halogen Headlamps
LPSS CHMSL Lamp MFNS Body Color Grille MGAS Ram's Head Badge
MHAS Black Windshield Moldings MWHS Rear Wheelhouse Liners NBKS EVAP Control System
NF4S 25 Gallon Fuel Tank QX8S Black Clear Coat SBAS Variable Assist Power Steering
SDBS Heavy Duty Suspension SHAS Front Stabilizer Bar SHCS Rear Stabilizer Bar
TBBS Full Size Spare Tire TBMS Tire Carrier Winch XDXS Scissor Type Jack
YAAS Build To U.S. Mkt. Specifications Z5AS GVW Rating - 6400# 1AAS U.S. Dealer Retail
142S Zone 42-Detroit 6USS U.S. Specifications Label 623S Michigan Ship to State Code
923S Michigan Sold to State Code
Optional Equipment
*HJ Leather Trimmed Bucket Seats -AZ Agate ADJ Heavy Duty Service Group
AFHP Overhead Convenience Group AHC Trailer Tow Group AJBP Security Group
ASPP SLT Decor Group ASU R/T Group ATK SLT Plus Decor Group
A07P 5.9L Engine(EML)/4Sp Auto Trans(DGT) BCQP 750 Amp Maintenance Free Battery CADP High Back Bucket Seats
CBLP Suede Door Trim Panel w/Map Pocket CFMP 2nd Row 40/20/40 Fold Tumble Seat CFP 3rd Row Seat
CLEP Front Rear Floor Mats CUCP Floor Console CUNP Overhead Console
DGB All 4-Speed Automatic Transmissions DHAP Lock-Up Torque Converter DHCP Full-Time Transfer Case
DMHP 3.92 Rear Axle Ratio DRBP Corporate 9.25 LD Rear Axle DSAP Anti-Spin Differential Rear Axle
Page: 2
Options Report
EAAC All Engines EML 5.9L V8 MPI Engine GNCP Sun Visors w/Illum Vanity Mirrors
GNTP Rear View Auto Dim Mirror GTS Power Heated Mirrors, Fold-Away GVBC All Vehicles W/Power Mirrors
JJJP 12V Power Outlet Mounted in IP JPSP Power 6-Way Driver Seat K2XP BLACK CLEAR COAT - MOLDING
K5XP BLACK CLEAR COAT - WHEELFLARES LBCP Glove Box Lamp LBDP Ash Tray Lamp
LCDP Map/Dome Reading Lamps LDAP Underhood Lamp LNJP Fog Lamps
LSAP Security Alarm MBQP Body Color Rear Fascia MLHP Body Color Front Fascia
MRLP Body Color Running Boards MURP Dodge Badge MUSP 4X4 Badge
MWGP Roof Rack MZDP 5.9 R/T Badge MZJP Durango Bright Badge
NAA Federal Emissions NEAP Sport Tuned Exhaust w/Chrome Tip NHBP Auxiliary Transmission Oil Cooler
NHFP Power Steering Cooler NHMP Speed Control NMCP Heavy Duty Engine Cooling
PX8 Black Clear Coat RAAC All Radio Equipped Vehicles RAZP AM/FM Cassette Compact Disc Radio
RCKP Infinity Speakers RDDP Fixed Long Mast Antenna RDZP Steering Wheel Mounted Audio Ctrls
SCGP Leather Wrapped Steering Wheel SFCP Front Perf Tuned Shock Absorbers SGCP Rear Perf Tuned Shock Absorbers
SUAP Tilt Steering Column TXPP P275/60R17 BSW All Season Tires TZAP Goodyear Brand Tires
WFRP 17X9.0 Aluminum Wheels WKBP Matching Spare Wheel YGAA Without Billable Fuel
ZARP Spring - Left Rear ZBAP Spring - Left Front ZNRP Spring - Right Rear
ZPAP Spring - Right Front 0Z5A FAM: DN TRACKING: 90701T09 MY:2000 0Z6A FAM: DN TRACKING: 90715T00 MY:2000
0Z7A FAM: DN TRACKING: 90726T02 MY:2000 00BA FAM: DN TRACKING: 91013T15 MY:2000 2TGA Customer Preferred Package 2TG
28G Customer Preferred Package 28G 3KVA SLT Plus Decor Group Discount 3VTA Customer Preferred Discount
4EA Sold Vehicle 4XN Rear Air Conditioning Bypass 5TV BusinessLink Inventory
515 Build Out Tracking 57F Status D to D1 Less 100
Special Equipment - No Special Equipment Available
Special Equipment
Dealer Installed Option - No Dealer Installed Option Available
Old Mar 12, 2013 | 05:35 AM
bwdakrt's Avatar
bwdakrt
http://geniusv.in/index.php
Old Mar 12, 2013 | 11:59 AM
MrDurangoRT
hey i read that list some of that stuff i know i have some im not shure but i saved it incase i need to look up part or somthing later
and the vin check came back with 1 wreck way back in 2004 dose not give any info on that much and a few other things but nothing major but thanks alot for help guys
also would a small battery cause the slow shift and hard cold starts? my 94 dodge 1500 with 360 in it had this huge battery in it i dont have that one anymore but this durango is kinda same thing as it was. but the battery is small like a honda civic batt or maybe a ranger lol its smaller then my g-maws oldsmobil one >.< it has no markings or pappers on it i assume it was a custom make it yourself batt or w/e but it is rather small just thought maybe that could be a cause of it
Old Mar 13, 2013 | 12:04 AM
master tech
The problem maybe the drain back valve on the 1500 Ram. This was a commom problem in the early years of the 46RH transmission. The other was the governor valves.
