Cant start
well wasent gona use parts for a 4.7l just info n video on where n how to replace the ignition coil and camshaft sensor if needed. ill call n order both from autozone n replace one at a time might buy a distributor cap if it dont cost to much also just incase it dose look really old
The parts probably won't necessarily be in the same places. For example the 5.2 and 5.9 have 1 ignition coil and a distributor while the 4.7 has a separate coil for each spark plug. Just to be clear too, it's the crankshaft sensor that may be causing issues here and probably not the camshaft sensor.
ill check fuse frist since i dont need a tool for that. not exactly shure how to check a plug on a car on my lawnmower i just pulled the single plug n put it to the metal wail i pulled the cord. somthing tells me i shouldent try that on my truck lol
its to dark n honestly to cold to do much right now when it get its lil warmer with some daylight tomorrow ill start on checking the plugs n things again n repost anything tomorrow thanks alot for your help
hey i got up this morning n thought about the relay for some dumb thing or another i did not think to check the relay and i got really lucky thats all it was. switched it out with another n got to autozone n had a hard time finding one but we got a new one and it starts on a breeze n runs great
thats alot for your help thatguy hope any1 else who has start problems reads this fourm finds it helpfull
