How to remove Steering gearbox??
Old Apr 2, 2013 | 09:10 PM
DallasD86's Avatar
DallasD86
Default How to remove Steering gearbox??
I am looking for help on how to remove my steering gearbox.
Old Apr 2, 2013 | 09:12 PM
DallasD86's Avatar
DallasD86
I have a 1999 dodge durango 4x4 5.9 and I am looking for help on how to remove my steering gearbox.
Old Apr 2, 2013 | 09:29 PM
wes00durango's Avatar
wes00durango
do you wave a pitman arm puller ?
Old Apr 3, 2013 | 05:30 PM
DallasD86's Avatar
DallasD86
No I do not but I was going to rent one from the auto parts store.
Old Apr 3, 2013 | 08:22 PM
wes00durango
If you know how to use a pitman arm puller it is pretty straight forward. just make sure you do not turn the steering wheel after disconnecting the shaft from the box. I push seat up and run seatbelt trough it and then move seat back to lock it in position. If u just use the ignition lock u will not be able to move the suspension back and forth to get right angle to seperate pitman arm. make sure u have a line wrench for power steering lines. I think it is an 18mm maybe a 16mm. when u fill system back up with fluid work steering wheel lock to lock with engine off and suspension in air. that will bleed system so when u start it u dont put wear on the ps pump.
