Idle Control Valve Problems
Old Apr 8, 2013 | 05:29 PM
trichards48's Avatar
trichards48
Unhappy Idle Control Valve Problems
I just replaced the Idle control valve on my 5.9L Durango. After replacing it I also reset the computer. Now it starts but it is idling at almost 1600 RPMs, I know this is not normal. I went to go get the code scanned and its giving off a p0505. I called the dealer they said if you drive it for about 10 miles it should just correct itself. I have done that, and still nothing. Any ideas?
Old Apr 11, 2013 | 12:50 PM
wallkicker's Avatar
wallkicker
I have a 5.2 98 durango with the same situation . I didn't get it scanned , but I heard the same thing . I am going to double check for vacum leaks and drive it some more . If you figure it out , please post how you fixed it or maybe someone else has the answer .
Old Apr 11, 2013 | 01:38 PM
that_guy's Avatar
that_guy
Nevermind just read you reset the computer. Driving it some could get the computer to re-learn things again, but there's probably something else going on.
