98 Durango won't start... please help...
Old Apr 21, 2013 | 05:31 PM
mstein7538's Avatar
mstein7538
Default 98 Durango won't start... please help...
So I'm trying to help my friend he just got from being deployed and doesn't have a lot of money so we are trying to fix this ourselves. He has a 98 durango and the rear wiper stayed on and drained the battery. I recharged the battery and now the truck just cranks over. I tried to connect a scanner to the ODB port and it can't connect to the truck. I don't hear the fuel pump kicking in either. I'm not sure where I should start to trouble shoot. From what I've read it can be the crank sensor, cam sensor, ECM or fuel pump. I also read that these can get messed up when you charge the battery from to much amperage. Any help would be appreciated.
Old Apr 21, 2013 | 05:44 PM
that_guy's Avatar
that_guy
If it was fine before the battery went dead the battery is probably the problem.
Old Apr 21, 2013 | 05:46 PM
mstein7538's Avatar
mstein7538
It will crank over til sunday but wont start, I don't think its the battery.
Old Apr 21, 2013 | 07:05 PM
that_guy's Avatar
that_guy
That doesn't mean it's not the battery. Was the truck fine before the battery when dead?
Old Apr 21, 2013 | 07:22 PM
mstein7538's Avatar
mstein7538
Yes the truck was fine. So please explain how it's the battery?
Old Apr 21, 2013 | 07:25 PM
that_guy's Avatar
that_guy
The computers can be very picky about the batteries. If they're weak (which is probably the case here) or even if there isn't a good connection to the battery all kinds of goofy things can happen with the computer including keeping it from running.
Old Apr 21, 2013 | 07:31 PM
mstein7538's Avatar
mstein7538
Thanks I'll start there first.
Old Apr 21, 2013 | 07:38 PM
that_guy's Avatar
that_guy
Try another battery that you know is good and it will probably be fine.
Old Apr 21, 2013 | 07:39 PM
mstein7538's Avatar
mstein7538
Ok thanks
Old Apr 26, 2013 | 05:23 PM
mstein7538's Avatar
mstein7538
Installed a new battery and it still just cranks over and doesn't start. I checked all the fuses and relays and they are fine. I'm still not able to read the cars computer with my scan tool. I have a feeling that the ECM is dead. When I go to start the vehicle none of the gauges move, like they are not getting any power. This is puzzling as the fuse for the dash is good. Should I look at getting a new ECM?
