Valve cover replacement 1999 5.9 Driver
Old Apr 24, 2013 | 07:53 PM
majerus's Avatar
majerus
Default Valve cover replacement 1999 5.9 Driver
Hey everyone, I have search the forums and the internet and cannot find any info on valve cover replacement. I seem to be running into issues removing a wiring harness connection in the PDC(power Distribution Center). If anyone knows how else to remove the valve cover without disconnecting the wiring harness I would love to know how. I am really just trying to replace the valve cover gaskets but a removal process seems necessary in order to do so.
Thanks for any and all the help.
Old Apr 24, 2013 | 11:36 PM
that_guy's Avatar
that_guy
there should be diagrams and instructions in the FSMs. (<-that's a link to them)
Old Apr 25, 2013 | 12:38 AM
majerus's Avatar
majerus
Wow great link. I am looking for the info now.
Old Apr 25, 2013 | 09:01 PM
majerus's Avatar
majerus
So I was able to change the gasket. I had to remove the wiring harness from the PDC, along with the positive and negative connections prior to being able to remove the valve cover. Once it was removed I used a razor blade to clean the surface on the head and then wiped it down with some paper towels re installed everything and now it seems to be smoking .
I have let it run to normal operating temp then shut it down twice now and seems to keep smoking. What would you guys suggest I check? I snugged all the bolts down fairly tight, in a adjacent pattern.
I was really unable to find the procedure with the FSM
