1-2 shift at WOT
Old May 6, 2013 | 07:36 PM
98ncdurango's Avatar
98ncdurango
Default 1-2 shift at WOT
quick question, 98 5.9 4x4 118xxx miles (says the odometer), while at WOT the transmission will not shift into 2nd gear, will just bounce of rev limiter. let off the gas, tranny will shift into 2nd, normal driving is fine as well. fluid is good, no fishy smell and is full, what needs to be replaced?
thanks in advance.
Old May 6, 2013 | 08:05 PM
that_guy's Avatar
that_guy
Id start by adjusting the TV (throttle valve) cable that goes from the throttle body to the transmission. Instructions for adjusting that properly should be over in the service manuals in the diy section. Here's a direct link.
Old May 7, 2013 | 07:51 PM
98ncdurango
thanks for the information. if that doesn't work, is their a solenoid that may need to be replaced? if so, which one should I start with?
Old May 7, 2013 | 10:07 PM
that_guy's Avatar
that_guy
I couldn't tell you. Transmissions with electronics in them are all new to me. Mastertech is a chrysler transmission tech and should be able to help. If he doesn't chime in here shoot him a pm.
Old May 8, 2013 | 04:13 PM
alwaysclean19's Avatar
alwaysclean19
I used to have the same problem, I took the first option and adjusted the TV. It is sort of fixed, it doesn't do it 1-2 anymore. Now it does it 2-3 at WOT. But it is weird because it no longer goes to red line it happens between 4.8-5k RPM and it just hesitates to shift, its the weirdest feeling I assure you.
Hope adjusting the TV works fine for you though!
Old May 8, 2013 | 10:52 PM
adukart's Avatar
adukart
This could be the governor pressure solenoid. That was a common issue, if they wore out it would peg the limiter at WOT. Mine does this too when the trans gets warm, like during towing. I would do the TV cable adjust, change the fluid/filter, and adjust the forward and reverse bands of the transmission.
Old May 9, 2013 | 02:29 PM
98ncdurango
I don't know anything about going into the tranny and adjusting the bands. id prolly just make it worse if I go into it and start adjusting stuff. Im going to start with a fluid/filter change, being that I already bought a filter because of the bad rep the trannys have. if that don't work then the cable and governer
also what tranny do I have?
Old May 9, 2013 | 02:46 PM
that_guy's Avatar
that_guy
5.9 = 46re
5.2 = 44re
4.7 = 45rfe
For some stupid reason the damn forum software keeps changing RE and RFE to lowercase if I capitalize them in the transmission name. WTF?
Old May 9, 2013 | 04:25 PM
alwaysclean19
Gremlins
Old May 10, 2013 | 02:03 PM
98ncdurango
thanks for the help fellas. will update when I get to turning wrenches on this.
