font drivers side thumping
Old May 21, 2013 | 05:20 PM
murfy101's Avatar
murfy101
Default font drivers side thumping
Got a 99 5.2L v8 mag 4x4 rango, got it pretty good n stuck last night and took 6 hours and two other trucks getting stuck to pull me out but we got it out with a new jeep liberty on 35 mudd dogs, at first he tried to pull me out and tht got no where then he jerked and pulled me out with ease we had the hook under the bumper in one of the holes in the frame and Idrove it about twenty miles home last night and it was fine well ths morning it has a thumping in the front drivers side like the tire is flat but its not, any ideas?? Anything helps point me n the right spot thanks guys
Old May 22, 2013 | 07:17 AM
SmokinJoe02's Avatar
SmokinJoe02
Lift it up and check the wheel. Could be a hub bearing or suspension related.
SJ02
Old May 22, 2013 | 09:03 AM
murfy101's Avatar
murfy101
I'm thinking its a bearing or where the front axle connects to the rotor I'm no professional mechanic but I do work on my own truck there ain't much I can't do but if Iknow I'm in to deep ill have my cousin come help me but it only thuds when coasting
Old May 23, 2013 | 06:13 PM
hydrashocker's Avatar
hydrashocker
Might be mud on the inside of the rim.
Also you could have knocked loose/broke one of the alignment bolts. If there is no mud on the inside of the rim get it in and have it looked at!!!!
