Noisy Timing Chains 4.7 L
Old May 21, 2013 | 06:33 PM
2000DurangoOwner's Avatar
2000DurangoOwner
Default Noisy Timing Chains 4.7 L
Ok, so every time I start up my rig, I get this nasty ticking and chattering noise coming from the front of the motor until it warms up. The rig has 126000 miles on it, so would the timing chains be going already?
Old May 21, 2013 | 09:52 PM
murfy101's Avatar
murfy101
I have a 99 durango with 160000 miles and its a v8 magnum 5.2 and it just started the other day and stays after its even warmed up
Old May 21, 2013 | 11:42 PM
OffTheTimeline's Avatar
OffTheTimeline
Mine's an '02 sxt, I have a similar sound coming from the side where the airbox is located. I was told by a couple different people that it most likely is the exhaust manifold gasket that's loose.......?
Old May 22, 2013 | 12:19 AM
djibara's Avatar
djibara
My 05 Dakota 4.7 has 190000 miles on it and the lifters tic for about 2-3 mins upon start up first thing in morning then goes away completely just let it warm up and its all good
Old May 22, 2013 | 10:32 AM
2000DurangoOwner
It isn`t the lifters. I know lifter noise when I hear it. This is coming from the front of the motor.
Old May 23, 2013 | 06:16 PM
hydrashocker's Avatar
hydrashocker
Well that is where your timing chain tentioners are, and you could have popped one off. Also it could be one of your cams and your lifter popped out because you have a 4.7L.
5.2L and 5.9L both like to tick a little, however you could have blown a Pentium gasket.
