Add-a-leaf question
Old Jun 1, 2013 | 10:28 PM
twodogs575's Avatar
twodogs575
Default Add-a-leaf question
I'm going to do the torsion bar lift but want to use the add-a-leaf approach in the rear as I plan on towing a lot. Of the folks who have done the add-a-leaf, what products and or techniques have you used and had success with? I have a '99 318 4x4.
Thanks, Jeremy
Old Jun 2, 2013 | 02:35 PM
moe7404's Avatar
moe7404
an air lift system might be what you need. all so there are shops that make added leafs custom. we have a shop here in wichita ks. they make leafs to hold any weight you need. it might not be cheap. but a good co can fix your trouble. look in the phone book, or the internet
Old Jun 2, 2013 | 10:25 PM
lvphotos's Avatar
lvphotos
Axle is on spring! The add a leaf will lower it. I cut up a set off another spring pack. But my axle was flipped from top of spring to bottom with 6" lift. Air springs are the way to go for towing.
