are these headlights worth it?
Old Jun 7, 2013 | 08:27 AM
alwaysclean19's Avatar
alwaysclean19
[QUOTE=that_guy;3029433]Are there separate connectors for the white and for the amber LEDs?
Yes there are. The headlights make use of the factory sockets and each led row plugs into the socket where the bulb used to be.
I think what I am going to do is drill a small hole in the socket and cut and run the wire for the white LED row through there and tap it into the corner/marker lights. That way it would come on and stay on with that light as a DRL.
Old Jun 7, 2013 | 04:59 PM
that_guy's Avatar
that_guy
All you need to do is flip the + wire for the white LEDs to the opposite side of the connector then they'll be parking lights.
Old Jun 8, 2013 | 12:07 AM
alwaysclean19
I think I tried that and it results in them not being lit at all... but It's worth another shot the next time I get some time to take the headlights out!
Old Jun 8, 2013 | 11:29 AM
that_guy's Avatar
that_guy
Maybe they're wired different then. The little LED cluster on my headlights was setup so that it would plug right in and function as a turn signal only, so I just flipped the wire on the connector where it plugs into the factory wiring to the other side.
