are these headlights worth it?
found these headlights on amazon. what do you guys think.
Those LED's could never work on his truck without some re wiring unless he has a Canadian model D. There for DRL which the US models never had OEM.
They wouldn't even work then without modification because the canadian drls ran the high beam at reduced voltage. They could be wired to come on with the ignition, or from one of the relays in the pdc that only gets power when the engine is running. They could just be used as parking lights too.
I looked at those when I was considering headlight options and I agree that without some creative wiring that those LEDS would not work for the truck. The LED's I have on my truck use the stock wiring by making use of the signal bulb socket to plug into so that it fits directly into the stock setup. Being as this has both signal lamps and the LED strip on the headlight I cannot see how this would work.
These are the ones I ended up going with and they are still working fine 4 months later.
Yea its kind of Illegal here too... but I have not had a problem as of yet. (there are bigger problems to deal with and the officers on Long Island while being the highest paid in the country are not motivated to do anything besides pull over a speeder now and then) Now as for the wiring white to DRL and amber to turn signal, that is how I thought it was going to be originally, however I was wrong. I am working on a way to tap the white LED wiring into the marker/park lights on the outside corner of the headlight. If I can figure out a way to do it without damaging the wiring I will let you know.
Trending Topics
See we have the opposite here.... The township and boro officers are the poorest paid law enforcement officers (compaired to PSP) yet they have the will and power to go above and beyond the call of duty to be the biggest a$$holes in town. I would much rather deal with a state trooper because chances are they will just make you aware it is not legal and give you a warning w/ a few days to correct it. With the locals your getting a citation for it and whatever else they can find along the way.
now back to topic.....
I guess ill have to buy a set and see how i can mod them.. There are a few on E-bay where the seller states that they can be modded by a pro installed to a aftermarket DRL unit. The unit's i have seen on Amazon for $20-$30 dollars.
Didn't you mention a while ago that PA was passing a law against LEDs unless they're factory?
Only thing i worry about with those is the phillips bulbs getting to hot and cracking the housings.
