brake piston
Old Jun 8, 2013 | 11:56 PM
phin's Avatar
phin
Default brake piston
2002 D SLT, Can't seem to push the Lt front brake piston back to put on new brake pads.
IT feels really hard .IS the caliper stuck?. new calipers?. Thanks
Old Jun 9, 2013 | 12:27 AM
Klokworx's Avatar
Klokworx
if you didnt use a c-clamp or dont have one try opening the bleeder valve and squeezing it with the clamp or wedge a screwdriver in there to pry it out. just watch you dont get brake fluid all over the place, put a clear hose over it
Old Jun 9, 2013 | 02:00 AM
phin's Avatar
phin
Thanks for the reply. I did use a c-clamp,but i'll try opening the bleeder valve and see if i can squeeze itback.Is it easy to put the piston back once you pry it out?. This is unknown
territory for me.
Old Jun 9, 2013 | 09:33 AM
pkucan's Avatar
pkucan
I believe the bleeder screw is the preferred method but I just open the reservoir cap.
Go slow when compressing the piston because the fluid will shoot out of the reservoir. I don't use the bleeder screw because I'll have more problems if I break it off! Beenthere done that!
Old Jun 9, 2013 | 12:17 PM
phin's Avatar
phin
I did open the reservoir but it would not move at all.This has never happen to me before
this is not normal and i think i would have to change the caliper .
