Rebuilt Transmission Slipping
Old Jun 17, 2013 | 10:05 AM
Old_School's Avatar
Old_School
Originally Posted by swilliamson5590
I'll keep that in mind for next time i check it (probably tomorrow). I checked it after letting it sit at idle and switching through the gears a few times then back into neutral. The line was at the bottom of the ok line and I added another half a court which put it a little above the middle of the ok line. So that makes SIX not five, but SIX qts. Everywhere I have searched everyone has said 5 qts. That wouldn't be enough fluid and your transmission would eventually fail. Good thing I did my own research and had help from you or i would be without a vehicle again with a full time job and full time school. Thanks again I really appreciate it.
Last time i change my fluid i added 8 1/2 quarts to get it to the top of the ok mark.... I also drained the pan and the torque converter and added a cooler. IIRC it says in the FSM that all fluid level stated are guide lines as they chance very from manufacture tolerances.
