Which radiator do I need
Old Jun 15, 2013 | 06:09 PM
zombiehelghast69's Avatar
zombiehelghast69
Default Which radiator do I need
when i search for radiators I see with and without aux trans cooler. what does this mean? I believe mine has a small cooler in front of the radiator. are they the same, I just have to put my lines in?
vehicle is a 99 5.9L 4wd
Old Jun 15, 2013 | 09:01 PM
Old_School's Avatar
Old_School
If you have a small cooler between the radiator and the A/C condenser then you need the one WITH aux cooler... You have a aux cooler if you have the tow package (factory hitch ect)
Old Jun 15, 2013 | 10:36 PM
zombiehelghast69
I don't tow, so can I do away with it? Just use the other one.
The radiators are the same correct? One just has lines going around to the cooler instead of straight down the radiator. Can I take this cooler off and put it on the new radiator that comes with no lines?
Old Jun 16, 2013 | 08:56 AM
Old_School's Avatar
Old_School
The lines are part of the cooler, the difference between the 2 is the one for the cooler has the brackets/mounts for the cooler. You can delete the cooler but, i would not recomend it. The cooler you keep your trans even without towing the longer its gonna last.
