2003 Durango Power Steering pressure switch
Old Jul 26, 2013 | 09:43 PM
JDurango's Avatar
JDurango
Default 2003 Durango Power Steering pressure switch
I need help locating the pressure switch to the power steering for a dodge durango 4.7L V8.
I have read several forums and looked online for pictures or advise on locating the pressure switch and have been unable to do so. Several post suggest the switch is located off the high pressure line (silver line) coming from the pump. It should be a "T" coming off and the switch is located on the "T". NOT THERE.
There are two lines coming from the power steering accessories. One of them (the silver one) and another coming from the reservoir. Neither one has a switch connected to it. I also got under the truck and traced both lines into the (not sure of the exact name) rod that connects them to the steering and wheels. I can not locate a switch or wires coming from anything.
If someone has any information in regards to location it would be greatly appreciated. Not to be a jerk but please dont tell me "it should be there" or "its located off the high pressure line on the drivers side by the battery". I have already looked and can't find it.
Pictures would also be very helpful.
I found this post http://www.dakota-durango.com/forum/...d.php?t=146341 which shows a similar picture of my power steering and the absence of a "T" or switch
I should also mention I'm asking this because my check engine light came on and autozone said the code was P0551. I don't know if that would help anyone is figuring out what my problem may be.
Thanks again for any help
Old Jul 29, 2013 | 08:05 PM
1969CoronetR/T's Avatar
1969CoronetR/T
vaffanculo
I moved this thread to the correct section.
FF
