99 Durango, Coolant leak, Where is this? (Pic included)
Hey Guys!
I have a 99 Durango, 5.2. I've been having issues with it sputtering after driving for more than 30 min. One of the suggestions was to replace the Crankshaft Sensor. So I was attempting to locate it when I found this below!
Coolant in/coming from this tube/shaft. What is this? I am not able to get a chilton manual right now, and I'm not familiar enough to know what this is.
Pic 2 below gives a better idea of where it's at. Thanks for any help.
Not yet. I'm going to get a pressure tester on loan from the auto parts store tomorrow.
I'm confused as to what that open tubing in pic #1 is, where the coolant appears. Not sure if there should be a hose there or what. The opening is coming out from the firewall.
There should be a tube near the bottom of the bulkhead/firewall and the the A/C drain tube. But if you have coolant coming from that drain. Order a heater core. Are the floors wet or do you smell a sweet smell from the heater vents?
