Proper 46RE Overdrive operation?
55 seems awfully high, but then again the 45rfe is a mystery to me. I paid attention to mine today and at light throttle speeding up from a stop to 45mph it kicked into overdrive at 33mph and tc-lockup when backed off the gas to maintain 45mph.
55 is high?? That's perfect. In my Titan I always had to lock it into 4th gear (flow thru center console with shifter) when driving around town. Otherwise OD kick in at 45 and it was a pain having the shifting all the time. But that's mostly because I have a heavy foot. Three sets of tires in 50k miles to be exact,,
In town with your truck it would drive me nuts. Your truck doesn't produce nearly enough power to justify OD at 33mph. Wayyyyyy too much wear an tear and un-needed shifts.
It's only making constant shifts if you keep playing with the pedal. And even when I do need to speed up it usually doesn't have to change gears much, that's the nice thing about low end torque.
In the 46RE, (as I understand) the TV is only for the 3 speed part. The OD in the tail cone is electronic shift. The TV is the mechanical input for the 3 speed shift part. The computer monitors the Throttle Position Sensor (TPS) located on the TB. Besides whatever TPS info is needed for motor operation, that info apparently also contributes to the OD shift decision. Makes sense to me.
correct the TV cable controls the 3 speed hydraulically controlled 'drive' portion of the transmission, the RE denotes electronic control, in this case of the overdrive module, there are other hydraulic valves controlled electronically too, but it is mainly the OD module that engages electronically
