1999 Durango no priming?
Old Aug 20, 2013 | 12:25 AM
Vandals909's Avatar
Vandals909
Default 1999 Durango no priming?
1999 Durango 5.9L
I thought I had a fuel pump problem. I checked the relay and all was ok. I replaced the fuel pump and everything worked well for a day. Now it will turn over but will not start. It does appear the fuel pump will priming either.
Any idea's? Where should I look?
One person suggested a crank sensor? But It should primer regardless of the crank sensor.
What do you think about it being an ignition problem?
Thanks
Old Aug 27, 2013 | 01:06 AM
Vandals909's Avatar
Vandals909
Vehicle started and ran for about 1 day then stalled out again. Now it will not turn on the fuel pump at all. Scanner says Open circuit in fuel regulator?
Old Aug 27, 2013 | 09:17 AM
Vandals909's Avatar
Vandals909
getting NOBUS on odometer now?
Old Aug 27, 2013 | 01:08 PM
SmokinJoe02's Avatar
SmokinJoe02
How old is your battery?
SJ02
Old Aug 27, 2013 | 08:42 PM
Vandals909's Avatar
Vandals909
Battery is about 1 year old? It appears from all the post everwhere that I need a PCM, all of the symptoms for a faulty PCM seem to be the same symptoms that I have.
anyone ever used this place?
http://www.autocomputerexchange.com/...to%5D=&search=
Old Aug 28, 2013 | 09:27 AM
Vandals909's Avatar
Vandals909
I'm not sure where to send my money for a PCM. Every company I look up has terrible reviews?
I'm becoming frustrated.
