need help!
Old Aug 20, 2013 | 02:13 AM
Kristyhutch's Avatar
Kristyhutch
Default need help!
So im trying to get my durango running. About 3 months ago a few hours later after getting gas my Durango wouldn't start I was told it was the fuel pump. Well i just started working on it. I changed the fuel pump put new gas in and it'll only start for 2-3 seconds. It will only start longer when I spray starter fluid. I changed the fuel relay sensor the camshaft position sensor and still nothing. There is no fuel reaching the front. The fuel pump works we checked that. But im thinking Maybe the wiring connected to the fuel pump. . Any suggestions?
Old Aug 20, 2013 | 09:03 PM
shrpshtr325's Avatar
shrpshtr325
THE ULTI-MOD
https://dodgeforum.com/forum/dodge-d...s-section.html
hmmm need more information, what year? what engine? we arent mind readers
Old Aug 21, 2013 | 10:43 AM
Kristyhutch
Well I re did the wiring and now im thinking it might be the computer because its turning over just not starting fully
Old Aug 21, 2013 | 07:28 PM
shrpshtr325
THE ULTI-MOD
ill put this in the first generation section for you
do you have fuel pressure at the rails? if not then my guess is that you have a blockage in the fuel line, or got a new pump that was faulty
Old Aug 22, 2013 | 05:24 PM
Danny in CO's Avatar
Danny in CO
Some vehicles (and I bet the Durango) has a fuel cut-off switch which gets tripped in an accident. This switch cuts the power to the fuel pump. I have had this switch trip going over speed bumps! It is a simple fix. Find the switch and press it back on.
Old Aug 22, 2013 | 06:25 PM
that_guy's Avatar
that_guy
I've never heard of anything like that getting tripped when you hit a speed bump, although my one friend's impala would call onstar every time he hit a speed bump.
