Tie Rods- Paying garage vs. DIY
Tie rod ends are fairly easy to change. There is just the nut and cotter pin to take off and then unscrew from tie rod. The only (sometimes) hard part is getting the tie rod end loose from the spindle frame. The tie rod end is tapered. I have had good luck after taking the nut off by holding a big hammer on one side of the spindle frame (I can't remember the correct name) and then hitting the other side with another hammer. As yet this has always worked for me. Another option is to use a pickle fork.
Once the tie rod end is loose, unscrew from tie rod. Count the number of turns and screw the new one in the same number of turns. If you don't get it correct it will throw off the alignment.
If you're asking, it's probably going to feel tough ('there will be blood', on your knuckles anyway). But you have to ask yourself, do you want to go through the rest of your life paying others to do things? I'd rather buy tools.
I guess the main question is why are you replacing, from what I assume is the outer tie rod? Have you checked the inner tie rods? If you have new tires you really need to get it aligned after replacing tie rods. Not sure what year you have but best guess is that if they have not ever been replaced all your tie rods are probably worn out. Replacing them is not rocket science but you have to have the tools. A dealer will probably charge you more than the truck is worth. Find a reputable mechanic in your area to do the labor and if he doesn't have an alignment machine take it to a tire place. Good luck!
Counting the turns isn't always sufficient because replacement tie rod ends may or may not be made to the exact specifications that the oem part was. It's always a good idea to use a scale to measure the distance from some reference point on the tie rod itself to the center of the tie rod ends bolt, that way you know the alignment will be spot on.
@Danny in CO thanks for the walkthrough! That seems like a cake walk compared to the brake job I did on my Volvo, so I think I'll give it a shot myself.
@JeeperDon That is indeed the question, and I paying people to do things for me when I could learn to do it myself
@PkUcan and @That_Guy I will probably return it to the tire center I bought my tires and lifetime balance and rotation from to have them realign so that I know it's done correctly. Tires are almost brand new, and I'd like them to stay even
