PCV help
Old Sep 4, 2013 | 11:47 PM
ccexpress's Avatar
ccexpress
Default PCV help
Ok I have a 2001 4x4 with a 4.7. I am trying to find the damn PCV valve and it isn't where they said it should be (next to the oil filler pipe). I can only find what looks like a PCV valve. It's on the right side in the back (next to the fire wall) connected to the top of the engine right behind the last sparkplug. The hose T's off from the intake pipe (K&N Cold air intake) and runs to the back to what looks like the PCV valve (a straight piece not an elbow) and then a small bit of hose connected to a fitting.
Sorry for my ignorance but there is nothing on the valve cover that remotely looks like the PCV Valve unless I am wrong about what a valve cover is...
Old Sep 5, 2013 | 07:05 PM
moe7404's Avatar
moe7404
well well well. i have a dakota 2001 paper factory service manual. it does show the 4.7 engine. but NO where does it show where the PCV valve is. not in the engine section, OR the lubrication section. sorry
Old Sep 6, 2013 | 08:16 PM
ole silver 03's Avatar
ole silver 03
I am not sure how to move a link to show you how to do it, but goggle it and there are some u tube video's on how to do it and what it looks like, sorry for not being able to post it....good luck.
Old Sep 8, 2013 | 09:36 PM
shrpshtr325's Avatar
shrpshtr325
THE ULTI-MOD
the pcv on the 4.7 is attached tot he oil fill neck, its an elbow which is a twist lock into the filler neck
Old Sep 9, 2013 | 05:17 AM
FSTDANGO3's Avatar
FSTDANGO3
Push in a little and twist to remove
STEVE
