A/C Problems
Old Sep 7, 2013 | 10:54 PM
a_jayson76's Avatar
a_jayson76
Default A/C Problems
Hello I have a 2003 Dodge Durango. A few months ago I had the A/C serviced at a shop and was working great. But now when am stopped at a light or leave the vehicle running while parked it starts blowing hot air. Once I start driving again the A/C starts to cool.
Old Sep 7, 2013 | 11:38 PM
master tech's Avatar
master tech
Site Moderator & Tech
Welcome to DF
I will move your post to the tech section. You will get more response from the other members.
Old Sep 8, 2013 | 12:10 AM
that_guy's Avatar
that_guy
Sounds like an issue with not getting enough airflow through the condenser. Check to make sure that the electric fan is coming on when the a/c is on.
Old Sep 8, 2013 | 09:40 PM
shrpshtr325's Avatar
shrpshtr325
THE ULTI-MOD
+1 on the efan not coming on as it should
Old Sep 9, 2013 | 03:57 PM
Kensai's Avatar
Kensai
Also, you may want to take it to a car wash and use the high pressure water gun to blow out and clean out your a/c condenser and possibly radiator to allow more air flow if the E-Fan is working.
If Efan and power washing your condensor does not resolve the issue. Check the fan clutch. Could have gone bad.
