remote starter
Old Oct 2, 2005 | 02:47 AM
bakeman's Avatar
bakeman
Default remote starter
I have hooked up an AUTO COMMAND remote starter and my check engine light comes on in my 2000 durango how do i get it to go out. I have double checked all the wiring .
Old Dec 28, 2005 | 07:44 PM
jerjenple's Avatar
jerjenple
Default RE: remote starter
I had the same problem in my D, what we ended up finding out is that there is a 22guage green and red wire near the ignition lock tumbler that also needs to be powered when the vehicle is started, for some reason the wiring diagram I had never indicated that this wire needed connected. If the wire is not connected the check engine light will come on and will scan with a code p1698 indicating no transmission signal, from what I have been told this can damage the transmission over time since that wire feeds power to the transmission computer.
Old Jan 1, 2006 | 12:43 PM
hydrashocker's Avatar
hydrashocker
I'm wondering if they make one of those (AUTO COMMAND remote starter) to turn on the old lady????????[sm=devilangel.gif]
Old Jan 4, 2006 | 02:41 PM
tattoohead's Avatar
tattoohead
Wishful thinking...lmao..
As long as it came with a KILL switch too...
Old Aug 5, 2006 | 05:54 PM
fastalker69's Avatar
fastalker69
How would you go about powering the wire and exactly where is it. I have a 2002 dodge ram that has remote start and this code comes up and also the trans is downshifting hard
