winshield leaking?
Old Sep 21, 2013 | 08:55 PM
tooltime's Avatar
tooltime
Default winshield leaking?
Durango is a 2001and the pass side floor board is wet. It has been raining and will rain Sunday. I am thinking if i could put some silicon on the inside or would that be a no no. I am going to put a cover over the winshield/top when i get home hopefully. Thanks
Old Sep 21, 2013 | 09:06 PM
that_guy's Avatar
that_guy
I'd be suspicious of either the heater-core or a/c evaporator drain leaking if it's just the passenger's side.
Old Sep 22, 2013 | 08:37 AM
tooltime's Avatar
tooltime
A few months ago i put the evap extension part on. It is not always wet. Rained yesterday and i checkedit last night and waswet. Weather shows no rain this week so i will keep checking it. It will leak only when running if it is the heater core?
Old Sep 22, 2013 | 11:09 AM
that_guy's Avatar
that_guy
Is it just plain water, or does it smell like antifreeze?
Old Sep 22, 2013 | 08:49 PM
tooltime's Avatar
tooltime
Seems to be water
Old Sep 22, 2013 | 08:52 PM
PublicHair's Avatar
PublicHair
Mine too was water. It's the drain for the AC system.
I couldn't reach up and unplug mine so I just drilled a hole in the floorboard at the lowest point and put a rubber floor mat (with the spike feet) under the carpet so whatever drains goes out my little drain hole. Problem solved. For now..
Old Sep 22, 2013 | 09:18 PM
that_guy's Avatar
that_guy
Find the drain hole inside the engine bay and stick a piece of rubber hose in it to clear it out.
