Replacing Heads and Gaskets.
Hello. I have small amounts of oil entering my cooling system. I am guessing I should do head gaskets and get new heads.
There is no smoke and no running issues. It runs great.
I am reading that oil entering the coolant = head gasket failure, and that these heads drop valve seats.
Am I correct?
I will be installing ARP head studs. This vehicle is a DD. Are the ARP overkill with stock power?
#1 head gaskets.
Should I get...
http://www.rockauto.com/dbphp/x,cata...Z_HS54237.html
or..
http://www.rockauto.com/dbphp/x,cata...HS26157PT.html
#2 Where do you suggest I get my new/reman heads?
#3 What else should I buy, upgrade, update?
Thank you.
Am I correct?
#1 head gaskets.
Should I get...
or..
Thank you.
http://www.ebay.com/itm/NEW-FITS-DODGE-JEEP-MAGNUM-5-2-5-9-318-360-CYLINDER-HEADS-/171027563637?pt=Motors_Car_Truck_Parts_Accessories&hash=item27d2098475&vxp=mtr#ht_3011wt_932
best you can get you can even get them a lil bigger valves for more power
