oil question
Old Oct 18, 2013 | 09:08 PM
tooltime's Avatar
tooltime
Default oil question
I bought some Castrol 5w30 high milage part synblend(or something like this). It is a 2001 Durango with a 4.7. I did not noticed it said the blend.Should iuse this or go back to Mobil? thanks
Old Oct 18, 2013 | 09:33 PM
moe7404's Avatar
moe7404
i would like to say what oil to use but i think the 4.7 might be different than my 3.9 V6. so ill let the 4.7 experts say what oil to use. but i like thicker oil than the factory say. iam just old school that way. i run valvoline premium blue 15w-40. factory fill for dodge Cummings diesel. but it might be to thick if you live above Kansas.
Old Oct 19, 2013 | 01:04 AM
RockGuardedDak's Avatar
RockGuardedDak
5w30 is what I run in mine. Brand is up to you. We all have our own preference.
Old Oct 19, 2013 | 06:24 AM
PublicHair's Avatar
PublicHair
10w30 here. Tho my vehicle is a spare so.. It only gets 40 miles a month on average.
I do notice oil consumption is a bit less with 10w30.
Old Oct 19, 2013 | 11:04 AM
JeeperDon's Avatar
JeeperDon
I'm a 'stick with one brand' motor oil guy. Others are fine too, but I've used Castrol regular dino oil for 25 years on everything. I'm not sure what the difference is in the 'high mileage' version is, but since my D is at 100,000+ as of 6 weeks ago, I started using that. I change the oil every 3,333 miles (easy to know when next is due, 3333, 6666, 0000). I rotate the tires and inspect the brakes then too, and check all the other fluid levels.
