I'm buying a used engine
Old Nov 13, 2013 | 08:28 AM
davidcareyf's Avatar
davidcareyf
Default I'm buying a used engine
Okay guys, I'm biting the bullet and hoping to get lucky with a used engine. The price for a 4.7 reman or rebuilt is over $4500 as far as I can tell. I have found just one, a single example of a 16 tooth, non 4WD, non engine mount, 4.7 here in the San Antonio area. It is at Pick and Pull, and they want $1000 for it.
So here is the question: what prep do you do with the engine before installation? I know I had the clogged oil pick-up tube in my first engine, so I will drop the pan on both engines and swap out the tubes. What else would you do to prep the used engine?
Thanks in advance
David
Old Nov 13, 2013 | 09:10 AM
dkishton1486's Avatar
dkishton1486
If you have an oil cooler also replace that or buy a new one. and basically just make sure it looks the same.
