rear end Noise
Old Oct 6, 2005 | 02:11 PM
Jasiangels's Avatar
Jasiangels
Default rear end Noise
I have a 1998 Durango, and have a loud howl in the rear end I changed the rear differential fluid, but it still is howling could it be the axel bearings?
Old Oct 11, 2005 | 12:57 PM
hydrashocker's Avatar
hydrashocker
Default RE: rear end Noise
Did you put the limited slip additive in the diff?[sm=tongue.gif]
Old Oct 12, 2005 | 07:06 PM
Jasiangels's Avatar
Jasiangels
We did indeed put the rear slip additive in there. We also changed or replaced the axle bearings, and still the noise, its driving us NUTS because we can't figure it out!!![:@] SO we are going to buy some new tiress and see if that is what is causing the problem, or could it be the bands that need to be tightened? I dunno any suggestions would help!! Thanks in advance!!
Old Oct 23, 2005 | 05:31 PM
hydrashocker
It could be the gears. I would have them checked out.
