Power windows not working
Old Nov 23, 2013 | 02:40 AM
M Shark's Avatar
M Shark
Default Power windows not working
I can control all 4 windows from the driver side control, but the individual window switches on each door can't open thier own windows.
Looks like a relay or fuse of some sort.
Any way to fix this? Thanks in advance!
Old Nov 23, 2013 | 07:28 AM
that_guy's Avatar
that_guy
Sounds like the window lockout switch is either on or it quit working. I believe its usually caused by the contacts inside it getting dirty. There is a diy on here somewhere to take the switch apart and fix it, otherwise you might need a whole new master switch assembly.
Old Nov 23, 2013 | 11:09 AM
TravisN.'s Avatar
TravisN.
yes, the window lock switch. in the DIY section there are ways to clean it and how to bypass it.
Old Nov 24, 2013 | 08:16 PM
Daves69's Avatar
Daves69
On my '02 I was able to get them to work by manipulating (bending it forward) the large yellow wire for a while. I could see the green LEDs come back on then the other switches would work. This only lasted a few months. I ran out of patience trying to get the case apart to clean up the contacts so I ended up buying a new one............
Dorman 901-448 Window Switch : Amazon.com : Automotive Dorman 901-448 Window Switch : Amazon.com : Automotive
