First time Durango Owner
Old Dec 13, 2013 | 09:40 PM
  #21
adukart's Avatar
adukart
+1. I'm inclined to agree. I would rather tow with my durango over a tahoe or ford anything, well I'll make an exception for the ole 7.3l diesel but that's a different class, because it does handle loads well. They are different from the dakota from the front doors back, heavier crossmembers and frame. The frame is also wider on the durango and I was surpised that its fully boxed front to rear, the 90's ram's weren't. That is the reason why dakota's are spring over and durangos are a spring under axel, its the difference in frame width. Most have the good ole' 9.25" rear end. They are also really heavy for their size. Mine sits at 5200lbs on the scale. Thats only 200-800lbs less than a brand new crew cab. The brakes aren't that bad, put in a decent set of pads and rotors and you'll be very happy. My brakes manage to handle GVW of 15,000+ with out issue. No vehicle is good for towing without the proper equipment, none.
Old Dec 14, 2013 | 08:02 AM
  #22
cmikolajczyk's Avatar
cmikolajczyk
Agreed, and a bit of knowledge for me. I knew that dodge took the Dakota and widened it, and boxed the frame in, but I've always been confused as to why it is a spring under unlike all the ram's I've had. (I figured it was for lower clearance, and so the cab could be lower for a family friendly height. I've tossed the though around about having a spring over axle to increase ride and clearance height, but I've yet to have heard or seen it done.)
End of story- Durango's are awesome towing trucks, regardless of what anybody thinks. If you disagree, please bring what you've got down to texas and we'll make a video of it.
Old Dec 14, 2013 | 12:49 PM
  #23
PublicHair's Avatar
PublicHair
Originally Posted by Magnum_D
So, a little update on my Durango......I changed the plugs (which on all the electrodes were wore down even with the porcelain), but I am still getting a Misfire on cylinder 2. The coil pack looked fine, so I'm wondering what should be my next step? change the wires and coil pack?.......or could there be something else triggering that code?
Also, the Durango is now running better and I have picked up about a 1-2 mpg gain
I had same issue. Changed coil pack. All went away. Until the spark plugs wore out (about 20k miles). Change spark plugs and haven't had an issue yet. ..then again I put maybe 2k miles on the truck this year? It just sits..
Originally Posted by cmikolajczyk
That's a bunch of crap, I tow every day for a living, and of course a durango will never compare to a heavy duty truck specifically made for towing! A dodge durango is a great towing vehicle, even in comparison to a 1500 series pick-up truck. I prefer my 98 5.9L Durango over my 1999 Chevy 1500 ext. Z71. It is a great pulling truck, and it handles very well, despite the shorter wheel frame. No older vehicle can compare to a newer one. There has been 15 years of new engineering into the motors. A 360 motor doesn't have the compression or HP like a newer hemi, but it's still a damn good pulling engine. I don't know where your comparrison's are coming from, but my durango can pull just as good if not better then any similar year truck of the same class. Maybe from a 3.9L V6 or a 4.7L V8, but surely not the big 360 magnum. It's platform is the only negative thing I have to say about the durango, that it would've been a better truck had the based it off of the ram opposed to the Dakota, but that's something they can't correct now. Oh how I would've loved to have a Ram 4dr SUV with a Cummins turbo under the hood, it would've ran ford's gas hog excursion out of the market.
For what you are hauling, a universal class 3 hitch from walmart will be more than enough. Depending on the wiring your trailers need, be conservative. If you're not pulling in excess of 5,000 pounds, you don't need to invest in trailer brakes, unless your trailer and/or state requires. A cheap $25 trailer light kit, along with a $50 class 3 receiver will be all you need. That's about how much it costs here in Texas. Be safe and happy towing !
..it's a bunch of crap but yet you said the same thing I said???
Old Dec 14, 2013 | 12:52 PM
  #24
PublicHair's Avatar
PublicHair
Well when you kiddos actually own/tow with newer SUV and trucks maybe then you'll realize the durango just can't compare very well.
But hey.. If it makes you happy. I just have experience vs pride so..
Old Dec 15, 2013 | 01:54 AM
  #25
cmikolajczyk
Originally Posted by PublicHair
Well when you kiddos actually own/tow with newer SUV and trucks maybe then you'll realize the durango just can't compare very well. But hey.. If it makes you happy. I just have experience vs pride so..
I'll consider buying a new suburban about the time I get $40,000 sitting around. You can buy a 98-99 durango 5.9 for about 3-4,000. Sorry, but to do the same thing, I am not a wasteful person, and I would prefer to use the money I don't have elsewhere.
And no, you still don't get the point. How did I agree with you? A new engine far out performs a older engine, everybody knows that. I've towed with a vast variety of vehicles from a ford explorer to a kenworth, so please don't get me started. I know what it's like to drive a new vehicle, I choose not to, because it's not economical to so in my situation, but it seems you have money to spend on a new dodge diesel to pull your toys, so I am quite certain I will not be able to explain why that is to you. This is a durango forum, if you're here to bash us owners, then please leave. There is enough criticism in this would without you here.
I do believe a Durango holds up well even today. I have my experience, you have yours. I am a hard working man like most of the rest of the fine respectable people in this forum. I just got done installing an aftermarket cam in a Pontiac G8, and I'm relaxing on the couch posting on dodge forum. Have a great day everybody, and drive safe.
Old Dec 15, 2013 | 12:29 PM
  #26
PublicHair's Avatar
PublicHair
Well enjoy your fairy tale and continue to think the durango is superior and that you think I'm saying "the durango can't tow" mindset. Clearly you're not reading a single thing I'm typing assuming I'm bashing the durango.
..and FYI I kept my durango for camping/snow/towing a quad to vacation property. So hopefully that clears things up for you guys being you keep thinking I'm saying other random ****. Sheesh.
