Check engine light - Code P138
Old Nov 24, 2013 | 11:34 AM
pitboard's Avatar
pitboard
Default Check engine light - Code P138
My check engine light came on. the code is the following
P138 M 1/2 O2 Sensor Shorted To Voltage Oxygen sensor input voltage maintained above normal operating range.
I also noticed when I start it for a few minutes the exhaust fumes are quite black and then after it warms up it goes back to normal. I also get 11.7 miles / gallon, not sure if it's in the normal range as it is my first V8 engine.
Thanks for any advice.
Old Nov 24, 2013 | 06:57 PM
JeeperDon's Avatar
JeeperDon
You need exhaust work. When mine did that (same code, also P0420), I put in a whole new exhaust, but I wanted a performance exhaust anyway. The cheap fix is probably swap out the cat conv and both O2 sensors.
