P0440 Gen Evap code
Old Nov 27, 2013 | 12:22 AM
master tech's Avatar
master tech
Site Moderator & Tech
Default P0440 Gen Evap code
Howardeer and to the others. Howardeer ask for a request for the P0440 code, So I thought I would post it for everyone.
Symptom:
P0440-GENERAL EVAP SYSTEM FAILURE
When Monitored and Set Condition:
When Monitored: Engine Running. Fuel Level greater than 12%. Ambient Temperature
between 4°C and 32°C (39°F and 89°F)
Set Condition: The PCM does not see the NVLD swtich close during the medium/large
leak test. The PCM then will increase the vacuum supply to the EVAP system by
increasing flow through the EVAP Purge valve. If the switch does not close with an
increase in vacuum an error is detected. Two Trip Fault.
POSSIBLE CAUSES
GOOD TRIP EQUAL TO ZERO
VEHICLE HISTORY AND SERVICE BULLETIN INVESTIGATION
VISUAL AND PHYSICAL INSPECTION
EVAP PURGE SOLENOID VACUUM SUPPLY INSPECTION
EVAP PURGE SOLENOID
NVLD SWITCH OPERATION
GROUND CIRCUIT OPEN
NVLD ASSEMBLY
NVLD SWITCH SIGNAL CIRCUIT OPEN
EVAPORATIVE EMISSION LEAK DETECTION
PCM
TEST ACTION APPLICABILITY
1 Start by reading PCM DTC(s) and record the related Freeze Frame data in any
DTC(s) are present.
Check the vehicle repair history.
If the vehicle has a repair history that pertains to the customer’s current complaint,
review the repair.
Inspect the vehicle for any aftermarket accessories that may have been installed
incorrectly.
Check for any service bulletin(s) related to the customer’s complaint or DTC(s).
If a service bulletin applies, follow the instructions per service bulletin.
Did the service bulletin repair the customer’s complaint?
All
Yes ! Testing Complete.
Perform POWERTRAIN VERIFICATION TEST VER - 5.
No ! Go 2
2 NOTE: If any of the following DTCs are set (P0443, P0452, P0453, P0498 or
P0499) diagnose them first before continuing with P0440.
Ignition on, engine not running.
With the DRBIIIt, read DTCs and record the related Freeze Frame data.
Is the Good Trip Counter displayed and equal to zero?
All
Yes ! Go To 3
No ! Refer to the INTERMITTENT CONDITION Symptom (Diagnostic
Procedure).
3 Perform a visual and physical inspection of the entire Evaporative Emission system.
Check for the following conditions:
- Hoses disconnected or left off
- Holes or cracks
- Loose seal points
- Evidence of damaged components
- Incorrect routing of hoses and tubes
- Fuel Cap left off or bad gasket seal
Were any of the above conditions found?
All
Yes ! Repair as necessary.
No ! Go To 4
4 Turn the ignition off.
Carefully inspect the Evap Purge Solenoid vacuum supply hose for proper routing.
Check for a pinched or plugged hose from the throttle body to the Purge Solenoid.
Make sure the vacuum port at the throttle body or intake manifold is free from any
blockage.
Were any problems found?
All
Yes ! Repair the vacuum supply, hose/tube as necessary.
No ! Go To 5
5 To continue testing you will need Miller Tool #8404 Evaporative Emission Leak
Detector (EELD).
WARNING: Keep lit cigarettes, sparks, flames, and other ignition sources
away from the test area to prevent the ignition of explosive gases. Keep the
test area well ventilated.
Connect the red power lead of EELD to the battery positive terminal and the black
ground lead to battery negative terminal.
Disconnect the vacuum hoses at he Evap Purge Solenoid.
Connect the SMOKE supply tip (black hose) to the service port (if equipped) or to the
#8404-ADP adapter.
Set the smoke/air control switch to SMOKE.
Press the remote smoke/air start button.
NOTE: Below is an optional method of checking the purge valve for leaks if
the EELD is unavailable.
Disconnect the vacuum supply hoses from the EVAP Purge Solenoid.
Using a hand vacuum pump, apply 10 in Hg to the 9CAN9 side of the EVAP Purge
Solenoid.
Observe the vacuum gauge for at least 15 seconds.
With the DRBIIIt, actuate the Evap Purge Solenoid.
NOTE: If the Evap Purge Solenoid does not hold a vacuum, it will need to be
replaced.
Is smoke visible from the Evap Purge Solenoid?
All
Yes ! Replace the Evap Purge Solenoid.
No ! Go To 6
6 Connect the previously disconnected vacuum hose.
Start the engine.
Allow the engine to idle.
Using the DRBIIIt, perform the NVLD FORCED MONITOR TEST.
Monitor the NVLD Switch state.
NOTE: As the test runs, the NVLD Switch should go from an OPEN state to
a CLOSED state and then return to OPEN when the test is complete.
Did the NVLD Switch operate as described above?
All
Yes ! Test Complete.
No ! Go To 7
7 To continue testing you will need Miller Tool #8404 Evaporative Emission Leak
Detector (EELD).
NOTE: The fuel tank should have between 20% and 80% of fuel tank capacity
to properly test the Evap system.
NOTE: See Charts and Graph support material EELD Calibration Setup for
an example.
Block the vent hose of the EVAP Canister.
Connect shop air to the EELD.
Set the smoke/air control switch to AIR.
Insert the tester’s AIR supply tip (clear hose) into the .040 orifice on the tester’s
control panel.
Position the red flag on the air flow meter so it is aligned with the indicator ball.
When the calibration is complete, release the remote button. The EELD flow meter
is now calibrated in liters per minute.
Install the service port adapter #8404-14 on the vehicle’s service port (if equipped) or
install the #8404-ADP into the filter line.
Connect the Air supply hose from the EELD to the service port (if equipped) or to the
#8404-ADP adapter.
Press the remote button to activate AIR flow.
NOTE: Larger volume fuel tanks, lower fuel levels or if the vehicle is
equipped with a Flow Management Valve, this may indicate high flow and
will require 4 to 5 minutes to fill.
Compare the flow meter indicator ball reading to the red flag.
ABOVE the red flag indicates a leak present.
BELOW the red flag indicates a sealed system.
Is the indicator ball above the red flag?
All
Yes ! Go To 8
No ! Go To 9
8 NOTE: A thorough visual inspection of the Evap system hoses, tubes, and
connections may save time in your diagnosis. Look for any physical damage
or signs of wetness at connections. The strong smell of fuel vapors may aid
diagnosis also.
To continue testing, you will need Miller Tool #8404 Evaporative Emissions Leak
Detector (EELD).
Remove the Air supply hose from the service port or the #8404-ADP adapter.
#8404-ADP adapter.
NOTE: The flow meter indicator ball will not move at this point.
NOTE: Make sure that smoke has filled the EVAP system by continuing to
press the remote smoke/air start button, remove the vehicle fuel cap, and
wait for the smoke to exit. Once smoke is indicated reinstall the fuel cap.
NOTE: For optimal performance, introduce smoke into the system for an
additional 60 seconds; continue introducing smoke at 15 second intervals,
as necessary.
While still holding the remote smoke/air start button, use the white light (#8404-
CLL) to follow the EVAP system path, and look for the source of the leak indicated by
exiting smoke.
If a leak is concealed from view (i.e., top of fuel tank), release the remote smoke/air
start button, and use the ultraviolet (UV) black light #8404-UVL and the yellow
goggles 8404-20 to look for residual traces of dye that are left behind by the smoke.
The exiting smoke deposits a residual fluid that is either bright green or bright
yellow in color when viewed with a UV light.
NOTE: The EVAP System is divided into three zones. Possible leaking areas
can be from any of the three Zones.
ZONE 1.
- Fuel tank valves (control valve and inlet check valve).
- Cracked, cut, warped, or missing primary fuel filler cap to fuel filler tube seal.
- Out of round fuel filler tube.
- Fuel filler tube to fuel filler hose connection.
- Fuel filler hose to tank connection.
- Fuel tank shell.
- Fuel pump module attachment.
- Gas cap loose or seal damaged.
- Gas cap internal valve.
- Damaged or disconnected EVAP system components.
ZONE 2.
- EVAP hoses loose or disconnected.
- Canister seals/hoses leaking.
- Canister housing.
- NVLD Assembly.
ZONE 3.
- EVAP Purge valve.
- EVAP hoses loose, cracked, or disconnected.
NOTE: Carefully inspect the vent side of the EVAP Canister. Due to the
filtering system in the canister the smoke or dye may or may not be visible.
Introducing smoke into the filtered side of the canister may assist in
locating the leak.
Was a leak found?
All
Yes ! Repair or replace the leaking component as necessary.
No ! Go To 12
9 Turn the ignition off.
Disconnect the NVLD electrical harness connector.
Check connectors - Clean/repair as necessary.
Connect a jumper wire between the NVLD Switch Signal circuit and the Ground
circuit in the NVLD electrical harness connector.
Monitor the NVLD Switch state on the DRBIIIt.
Does the Switch change from OPEN to CLOSED.
All
Yes ! Replace the NVLD Assembly.
No ! Go To 10
10 Turn the ignition off.
Measure the resistance between the Ground circuit and ground.
Is the resistance below 5.0 ohms?
All
Yes ! Go To 11
No ! Repair the open in the Ground circuit.
11 Turn the ignition off.
Disconnect the PCM harness connector.
CAUTION: DO NOT PROBE THE PCM HARNESS CONNECTORS. PROBING
THE PCM HARNESS CONNECTORS WILL DAMAGE THE PCM TERMINALS
RESULTING IN POOR TERMINAL TO PIN CONNECTION. INSTALL
MILLER SPECIAL TOOL #8815 TO PERFORM DIAGNOSIS.
Measure the resistance of the NVLD Switch Signal circuit from the NVLD electrical
harness connector to the appropriate terminal of the special tool #8815.
All
Yes ! Go To 12
No ! Repair the open in the NVLD Switch Signal circuit.
12 NOTE: Before continuing, check the PCM harness connector terminals for
corrosion, damage, or terminal push out. Repair as necessary.
Using the schematics as a guide, inspect the wire harness and connectors. Pay
particular attention to all Power and Ground circuits.
If there are no possible causes remaining, view repair.
All
Repair
Replace and program the Powertrain Control Module per Service
Information.
Old Nov 27, 2013 | 10:45 AM
Old_School's Avatar
Old_School
As usual good info!
Old Nov 30, 2013 | 05:43 PM
Howardeer's Avatar
Howardeer
Thanks a lot You have a befitting username
